Nothing happens when i try and squirt washers . Back one works so tried swapping pumps but still nothing. Do you think it could be wiper stalk fault?
Richard.
Front washers dont work?
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- MULLEY
I've got the exact same issue on my TZD Turbo, i swapped the pumps & neither worked on the front washer. Could it possibly be corroded contacts or perhaps the wiring is faulty?
Mine has done this occasionally but it is usually just the connections on the pump, disconecting the plug and putting it back on usually cures it. obviously if youv'e swapped pumps around it is unlikely to be this.
- smiffy1071
- pies are evil!
Did you try the common fix of bridging the earths out? (motor earth across to the lighting earth 2&3 from the right hand side)richardd1652 wrote:Swapped the wiper stalk yesterday and success, now got washers.
Also swapped heater rheostat control but still no blower so going to investigate further over weekend . Think ive got a spare blower somewhere.
Richard.
