Does aanyone have a guide for setting up the Bosch pump? Mine smokes quite badly (bad enough for MOT failure) when pushed and is also not quite returning the MPG i'd expect. It starts and run's perfectly and doesn't use oil so i think it's just a bit on the rich side.
Secondly, i've traced the spurious rear-end knocking:
Those who are aware, the rear suspension cylinder (ram) is mounted into a circular plate in the subrame (with the metal pipe in the side and the sphere on the end). Now, when going over bumps my cylinder is knoking up and down in that plate (it's only about 2mm movement) which is causing the knocking.
So, there's nothing technically wrong with it and normally when under pressure the cylinder would be so rammed up against the plate it wouldn't move but this one's just being an arse.
I've tried wedging things in between the sphere and the subframe lip below it but nothing's working. Are bright ideas?
Cheers.
Bosch pump settings & Knocky knock...
- JayW
- x 13
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 79
found you the bosch pump bible, on tother side. It's pretty detailed about construction, less so on the practical side of actual tuning.
Is it not all in the 'Diesel' haynes?
EDIT
To answer my own question there is a section on 'Fuel Injection Pump (BOSCH) - Checking the adjusting and static timing on page 96. (Grey cover, book 1379)
ANOTHER EDIT
Found the PDF's for the Diesel Haynes, have put it on the BXP and posted a link to it on the other side.
EDIT
ANOTHER EDIT
- MULLEY
I've never heard of the rear cylinder knocking against anything, seems a bit strange, has the circular plate been damaged or isn't in the correct position? Or perhaps the cylinder might be out of position? The only other thing i can think of is that its the wrong cylinder fitted & therefore the fit is wrong?
Bosch pump settings knock knock.
Dear JayW.
I know it sounds crude, but if you were to jack the car up and put
the car in low, so that the suspension cylinder is not under pressure. and
then warm the part of the subframe with a welding torch, and gently
apply a hammer to it, whilst it is hot, and then allow to cool : That should
sort the problem out, I would have thought
I hope this helps
Vince
I hope this helps
Vince
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
- mat_fenwick
- x 19
Re: Bosch pump settings knock knock.
I don't think Jay is bothered about thing being slightly crude...bx petrol auto saloon wrote:I know it sounds crude
Yes, those mankini photo's were well crude!mat_fenwick wrote:I don't think Jay is bothered about thing being slightly crude...bx petrol auto saloon wrote:I know it sounds crude
- JayW
- x 13
The plate is inaccessible with the cylinder/sphere in situ and i'll be buggered if i'm gonna take it all out for the sake of a knock that goes away above 20mph. Besides, the plate isn't bent, it's just my hole that's slackbx petrol auto saloon wrote:warm the part of the subframe with a welding torch,
What you trying to say Mr Fenwick?Way2go wrote:Yes, those mankini photo's were well crude!mat_fenwick wrote:I don't think Jay is bothered about thing being slightly crude...bx petrol auto saloon wrote:I know it sounds crude
Besides, i know you've all got poster-sized copies of the mankini pics on your bedroom ceilings
