Windscreen Seal
- Tim Leech
- x 141
Windscreen Seal
The one on the DTR will have to come out when the paint on the A posts is taken care off, is it a case of just cut it off and get a new one?
Thanks
Thanks
Be careful removing it Tim. Citroen lists it as NFP. Took me ages to source a NOS one.
I would imagine it just pulls off. I'm still holding out for a NOS bronze windscreen before I do mine. Once the screen is bonded in, the seal will be held in place by mastic, I would have thought.
Roverman wrote:The one on the DTR will have to come out when the paint on the A posts is taken care off, is it a case of just cut it off and get a new one?
mds141 wrote:Be careful removing it Tim. Citroën lists it as NFP. Took me ages to source a NOS one.
Roverman wrote:Think I can get one, are they difficult to remove
NO ! ( but virtually impossible to refit correctly, unless a new windscreen is being refitted ) !
mds141 wrote:I would imagine it just pulls off. I'm still holding out for a NOS bronze windscreen before I do mine. Once the screen is bonded in, the seal will be held in place by mastic, I would have thought.
Stop read THIS this thread first, you may change you mind re 'Just cutting/pulling the seal out'
- mat_fenwick
- x 19
i belive they are fitted onto the edge of the glass before it is bonded into place,
so to do a proper job it will need the screen removeing,
I pulled a trim out last week without any problem, much tighter along the bottom edge though which would suggest it was on the screen before it went in.
As for rounded edges, I've got cars with apparently original screens with rounded top corners on the trims so think Citroen may have changed the design at some point. Don't know if I have any square edged ones actually....
CCC BX Columnist
'89 16v P1
'93 ZX Volcane TD 3 Door
'98 Xantia Activa P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
'89 16v P1
'07 C4 by Loeb
3 x 2CV, 1 x Mehari
It's now in my impromptu citroen parts dept.mat_fenwick wrote:NT Louth had one - the screen company I used in January could get a pattern one but this has rounded top corners rather than squared off. Fits but looks slightly different, if that bothers you
