Power Steering problem.
Hi to all members out there.
Could someone please help me???
My problem is the power steering efficiency is very poor, it feels as though it is sticking at times when turning.
I have bled the hydraulics (lock to lock).
there was a stiff track rod end (just changed both).
On test drive power steering still very poor.
Hyd pump etc all ok it just seems to be the steering.
can someone give advice, and does someone have any good spares to enable changing.
Please help
Many thanks Geoff.
Please help
Many thanks Geoff.
Howdy. PAS problems are usually due to a weak pump or a Flow Diverter Valve that's clogged. A change of fluid may improve things (if this hasn't been done recently). Mine has this problem and I've not entirely worked out of it's pump or FDV yet. It is quite slow to rise, especially on tickover, so pump is looking like my chief suspect.
Power steering problem
Thanks to you both.
Pump fairly new purchased from A reliable source (GM) so i think that should be ok.
Raise times good, tick interval 25-30 seconds,
Can you suggest next stage ????
Regards.
Regards.
i would say first port of call would be pump belt tension, secondly check for dirty tank filters,
then move on to more complex theories,
- MULLEY
The cheapest option after checking the pump belt tension is to remove all the lhm, clean the lhm tank out & the filters & re-fill with hydraflush. Run for 1-2k & if that doesn't improve anything then its either the fdv or the pump (regardless of whether its newish/re-conditioned). Fingers crossed & keep us updated on how you get on & if anything changes/improves.
- barry badger
I've had two bxs with this problem, the steering would lock hydraulically when going around roundabouts or sweeping bends. I always thought it was the pinion valves that were faulty? Both cars were very high mileage and were scrapped without this problem being fixed. (after being extensively stripped)
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
powersteering fault
Thanks to all responses.
Belt tight.
I will strip and fit a repair kit to the FDV.
As suggested i will drain all lhm.
Clean tank/filters etc and fill with hydroflush.
After that it is a case of wait and see????.
Thanks again to all.
Belt tight.
- themildbunch
I've had exactly these symptoms on a very neglected BX I was given recently.. very slow to rise, intermittent stiff PAS until all warmed up..
I recently drained the very dirty and old LHM, cleaned the tank and refilled with the flushing fluid and so far no heavy steering... definitely worth trying this first as the hydraflush is cheaper than LHM!
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
Power steering problem.
Hi to all,
cleaned filters in tank, fresh lhm.
replaced fdv, and fitted new steering rubber/flexi jont.
Back on the road all is well.
many thanks to all for your info etc.
thanks to richard for the spares.
Keep Motoring.
Keep Motoring.
- Tim Leech
- x 150
Re: Power steering problem.
RESULT!!YorkieG wrote:Hi to all,
Keep Motoring.
- MULLEY
Glad its sorted, shame that you did all that lot so we won't know what actually cured the problem, might have been cumalative though?
I'm glad you've got it all sorted now Geoff and that the spares I sent were of help !YorkieG wrote:Hi to all,
Keep Motoring.
P.S. If anyone needs an FDV ? I still have a used one available, first come first served (so be quick as its my last one) !
