I hate diesel pumps...
- electrokid
and I expect it's mutual
I had a leak on the 'throttle' spindle (occasionally fuel leaking out but usually air leaking in) so yesterday I took the top off the pump and eventually decided just to replace the 'o' ring.
Reassembly was the nightmare I presume it's supposed to be and I had some difficulty getting it running again but eventually did. Before stripping it down I noted the max rpm (according to my rev counter which is probably a bit out) to be around 4750 and since I don't want the MOT test to blow the engine up I was trying to adjust it so it was no higher than that an possibly a bit lower. Although it seems to be running very well the rev limit is something over 5000 so I don't want to risk an MOT emissions test until I can fix the max revs.
So... Questions... (Bosch pump)
I've turned the fuel adjustment anti-clock - reducing the fuel - by several turns - did I reassemble something slightly differently for that to be needed ?
There's an adjustment to limit the movement in one direction on the cutoff lever - what does that do please.
At the moment, tickover is a little high but that should be no problem to change with the idle adjustment.
It does feel a bit 'livelier' than it used to - does that mean I'm still overfuelling slightly despite the new position of the fuel adjustment.
There's no smoke - but I've mixed one bottle of Forte with about 2 gallons of diesel and (prior to stripping the pump) thrashed the nuts off it a few times.
Ok - to be fair to diesel pumps this is the first one I've tackled.
2002 C5 HDi SX estate
- JayW
- x 13
Re: I hate diesel pumps...
That's certainly not right. One full turn on mine and it was running and sounding like a bag of spanners. Qtr turn made significant a difference to stop there.electrokid wrote: I've turned the fuel adjustment anti-clock - reducing the fuel - by several turns - did I reassemble something slightly differently for that to be needed ?
- electrokid
- electrokid
Thanks Andy - I'll give Malcolm a bell if I get stuck (and about his technique for keeping brake cables from rubbing as well ! ) My problem at the mo is I don't know when I'll get it back from welding - then Andy Baker will do the CV boot and the MOT runs out on Friday so not much time to squeeze it all in.
Unlikely but... are you also on vinylengine.com as Mothman ? (I'm on vinylengine as electrokid of course)
- electrokid
Hi,
Did you record the original positions of all the levers and screws.
It's imperative to do this.
I always accurately record with photos and scribe marks all, before dismantling.
If you do not, they are a pig to correct.
As you have found out, inter reaction between various adjustments.
Best of luck, and let the forum know how you progress.
- electrokid
I thought about taking a photo but didn't bother - I will if there's a next time though.
I'm beginning to think that what I would think of as the 'throttle max end stop' is the max revs setting so I'll try that when I get the car back - I called in this afternoon and they hadn't even started the welding job yet which was disapointing - I'll have another fiddle when I get it back - but I'm thinking 'pig to correct' is going to be right.
- electrokid
