Fuel filler neck top locking ring
Hi peeps..Does anyone know what part I need? Its the locking ring that allows the fuel cap/flap to seal shut that has rusted off the car, and is now held in by friction alone. As Andy is breaking a BX, I was going to ask him for the part, but I don't know the extent of that part. Is it the whole filler pipe I need?
Thanks in advance,
Adam
Thanks in advance,
Adam
- Vanny
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 82
A quick press of the search button would show you that this topic has been well covered recently;
http://www.bxclub.co.uk/forum/viewtopic ... iller+neck
- electrokid
yep, the BX project way , if it aint buggered when we start it will be when we're finished.Vanny wrote:If its a scrap car, angle grind a big chunk of body off with it?
Re: Fuel filler neck top locking ring
I've got fuel filler issues on both BXs. On the Mk1, I was struggling to get the screws to tighten up. Replaced some of them and it's now pulled tight, but it still leaks. Not good with diesel.
On the Mk2, the screws are just pulling out and leakage is also occurring.
So, it looks like I've failed to cure the issue with the Mk1, and need to cure both. What do I need?
- JayW
- x 13
The screws just run into captive nuts, take the neck off and you'll probably find the nust have rotted away. Easy replacement!
Phew. Thanks J. Something else for the to do list!
