Email should almost certainly be : pleiades@tesco.net without the extra . in the middle of tesco
I think the link that RXBX posted is reliable, the seller has 100% feedback on over four hundred transaction and for 14.99 pounds you can't really go wrong. But maybe he can't be contaced or won't post abroad as many Uk sellers won't for some reason.
Anyway, hope you're on the right track now
An opportunity to buy the brake valve, doseur
Re: An opportunity to buy the brake valve, doseur
-=RAMZES=- wrote:...........................................
Thanks for information but i'd like to buy from reliable persons...from true companies or persons with good recommendations of you...
I don't trust to internet sellers...
Todd I totally agree with you there, as they also had an FDV which did get sold, so if someone off the forum bought this ?toddao wrote:Email should almost certainly be : pleiades@tesco.net without the extra . in the middle of tesco
Maybe they could then put -=RAMZES=- doubts about 'Internet sellers' to rest (Well at least this one)
yes sorry i just tried to read it from my June Citroenian (dim light or is that wit )Dollywobbler wrote:Should that be tesco.net rather than tes.co.net?
definitely a senior moment
- docchevron
you can use a valve from an XM or Xantia if you get stuck...
It has now been RE-LISTED !RxBX wrote:.............................................
There was one on E-BAY recently which had zero bids on it (the listing ended on 19-05-12) !
I suggest you contact the SELLER to see if they could help you out with a buy it now (So long as their happy to send abroad), its worth a try 'If you don't ask you don't get'
I hope you get sorted out !
I am spartacus is someone needing this doseur valve ?
Stewart
Stewart
