Are these bonded in or something? I thought I remembered removing some years ago and just unbolted them, but could well have been thinking of an AX.
Can't see a way to remove them - the only fixing I can see is the bottom of a screw from the drop glass side once I've pulled the channel guides out.
'Tis weird
Rear door quaterlight windows
- x 88
1990(H) 16Valve (Rouge Furio)
- Tim Leech
- x 150
Re: Rear door quaterlight windows
Nope not bonded but are VERY tight and held in by a plastic piece the fits between the window and a folded up part of the door metal. When i did them I used lots of WD 40 and slid them out
- x 88
What a pig! Cheers Tim, all out now. Had to cut the rubbers a bit but no one will notice.
have done these myself they are not bonded just a very tight fit, the older the rubbers the tighter they will be, i think there is a small screw or rivet or similar holding the bottom of window on a metal plate u wont get it out without removing this first, good luck
