notched belt
notched belt
Hi guys, ive just been out and topped up the oil and then underneath to wipe up the leaks/drips. while poking around under the bonnet i noticed a notched belt with two notches missing... standing at the front of the car its the belt under right hand side of the intercooler looks like its running a pump?
Has anyone changed this and whats the level of difficulty...
Thanks!
Thanks!
Re: notched belt
That sounds like the pump belt, in which case you'd better change it pronto. Not too difficult, though getting the new belt on can apparently be a struggle and access will be improved by removing the intercooler. If the belt fails, it's goodbye steering, suspension and brakes.
Re: notched belt
thought it was something important! ... will get a belt and fit ASAP, was just a bit aprehensive about taking things apart then being stranded at work... Not too difficult sounds good.
thanks for your help
Re: notched belt
Just loosen the adjuster bolt, which allows you to move the pump closer to the pulley. As I say, I know some people have found that the new belt is a struggle to fit - that's the only problem I can forsee. Bear in mind that the tension needs to be really high or it'll slip - far higher than an alternator belt. Take a long bar to give you some leverage.
Re: notched belt
as Ian says but not only loosen the top adjuster 11mm nut and bolt, but also the 14mm pump pivot nut below the pump and towards the battery, and the adjuster arm/bracket 11mm bolt/nut,
fitting the new belt you might nave to move/pivot the pump on its pivot bolt to obtain enough clearance, for the new belt to go between the two pulleys,
also as Ian says it needs to be very tight
Re: notched belt
Very important to use a good quality belt and always carry a new spare belt in the boot, you really dont want to be caught out, as the guys above said this runs the hyd pump which powers your suspension, steering and brakes, fairly simple to change the belt just make sure you dont fracture or damage the metal pipe which connects to the flow valve or you will loose all your LHM in seconds.
Re: notched belt
thanks for the warnings/advice, i will take plenty of time this weekend, the thought of breaking a pipe is making me nervous! Will also carry a spare as a 'just in case' then if it goes again get the RAC guy to fit it.
Re: notched belt
the way to make sure not to brake the main pump feed pipe, is just slacken the 12mm flair/pipe nut that goes into the bottom engine side of the pump,
dont forget to nip it back up after you have fitted the belt
ps.
were are you located
ps.
Re: notched belt
Thanks, i will print all this info off before i start. Im in central Leicester (Midlands) with permit parking, no garage/driveway so have to do all repairs at work in the car park.
Its not too bad as i have keys to the building so have access to a kettle!
Re: notched belt
Certainly not a job to be scared of - my wife managed it in a motorway services just after we got the grey one!
Re: notched belt
wow! thats put me to shame lol
