I read the responses to the previous sphere enquiry with interest. I originally ran my 4x4 estate with 500/50/1.40 spheres on the back as recommended by gsf, the rear could be pushed down easily but it returned very slowly and on the road it felt very firm. I did a bit of research and found the correct spheres should be 500/40 with no valve, gsf number n45344. I ran it for a while with these but it still felt too hard at the back. So I then fitted two second hand (but good) accumulator spheres to the rear and it felt much better. This is how i've been running it for the last 12 months.
But I know it should feel better than it does so my questions are:-
Is the gsf part number right?
Would I be better off fitting two brand new accumulator spheres to the rear, 400/62, I think?
Was there a 500/62 fitted to anything?
More sphere questions
- barry badger
1993 tzd estate, on sorn
1991 4x4 estate, on sorn
- MULLEY
Re: More sphere questions
I thought it was an absolute no no to fit accy spheres to anywhere else? Can't help with your query either, sorry
heres GSF's sphere chart
http://cx.podolsk.ru/xm/docum/citroen_kule.pdf" onclick="window.open(this.href);return false;
Accumulator spheres have no damping valve in the neck and so would be equivalent to running a car with springs but no shock absorbers. If you say that the ride felt good with them fitted then either you never get sea sick, or never exceed 5mph. I think it is safe to say they were NOT accumulator spheres. I suspect they were just a pair of suspension spheres.barry badger wrote:So I then fitted two second hand (but good) accumulator spheres to the rear and it felt much better. This is how i've been running it for the last 12 months.
Michael, Sydney, Australia
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
- barry badger
They are accumulator spheres, I took them off bx regulators myself. The 4x4 doesn't have valved spheres on the back. I imagine the damping must be done in the pipework because the spheres are mounted remotely.
I'm tempted to try two of the 500/70 spheres listed in the application table posted by malcolm.
yes Barry looking at the drawing on service citroen,
what would usually be the valve on a corner sphere is in the end of the screw cap/bung, which fits through what looks like a giant banjo union, and screws into the cylinder as a sphere would,
although looking at the sphere in the drawing it does have a valve fitted, below are the two options for rear corner spheres dependent on rp No.
95 564 252
NFP
FRONT SUSPENSION SPHERE + GASK
400CM3 40BARS
- SALOON
5 457 447
NFP
500CM3 40BARS
- ESTATE
95 564 252
NFP
400CM3 40BARS
- SALOON
5 457 447
NFP
500CM3 40BARS
- ESTATE
How amazing! I am sorry, we never got the 4x4 here. That is an interesting solution. Maybe they wanted to isolate the connecting pipework from road shocks?barry badger wrote:They are accumulator spheres, I took them off bx regulators myself. The 4x4 doesn't have valved spheres on the back. I imagine the damping must be done in the pipework because the spheres are mounted remotely.
The sphere listed for the 4x4 is:
BX 4x4 95 564 252 402402 400 40 –
http://citroen.tramontana.co.hu/suspens ... nt-spheres" onclick="window.open(this.href);return false;
ie no damper. I guess fitting normal spheres would be like having double dampers, or worse. If the damperless spheres for the 4x4 are not available then a pair of new 400cc accumulators would be ideal, but perhaps you could have the pressures dropped to 40 bar, or 55 bar if you prefer a little softer. The standard accumulator 62 is a bit too high.
Better still just get the two accumulators presently fitted regassed to the specs you want.
BX19TRI Automatic
DS23 Pallas
BX19TRI Automatic
DS23 Pallas
