You can do the "sucking up" approach without removing the wheels, I do quite often. Just stick the side your doing on lock.
As stated above, If venturing underneath ANY hydraulic Cit and you dont have a 4 post lift then extreme caution is called for. Better to be safe than sorry etc.
I had a very close call a few years back when the back end of bx fell off axle stands while I was under it. Back then I was stronger and lifted the back end enough to get my legs out, but it could have been fatal if I'd gone under head first so SAFETY FIRST is paramount.
Chris G
citaerobics
- docchevron
- docchevron
MOT men are like chimps, you just need to train them to understand the complexities of citroen!
First year I had the diesel it failed the test cos there was no handbrake effort at all.... Guess why!
Needless to say I didn't use those plebs again!
Chris G
Chris G
All useful stuff, thanks a lot everyone. I've actually already done the sucking-up with the wheels on lock, as docchevron suggested, and the ride has improved markedly. I was simply wondering if there's any safe way of getting better access in order to replace the return pipe, i.e. by taking the wheel off.
As for MOTs, I've yet to experience the French controle technique, since they're only every 2 years, but hopefully the testers will be a bit less chimp-like about citroens
- Mike E (uk)
image1990 wrote:I was simply wondering if there's any safe way of getting better access in order to replace the return pipe, i.e. by taking the wheel off.
I did mine yesterday. Unles you have a proper garage ramp, I couldnt see any other way of getting the clip on the strut without removing the wheel. I also degreased and pressure washed hub / brakes ect. And as has been mentioned a pair of pincers similar to these work a treet.
http://bhinone.farnell.com/jsp/endecaSe ... sku=012400
