It would appear that my rear suspension cylinder has sprung a rather major leak.
Theres one down the scrapper i'm going to get tommorrow. Anybody know the best way to get one off?
Rear Suspension Cylinder
- Ian_Fearn
Over and out from me
Remove the sphere, remove the hydraulic line going in through the steelwork above it, make sure you completely remove the gland nut too at the front of the ram remove the steel clip and pull out the two plastic return pipes, removing the sphere will reveal a curly steel clip, remove this and tha ram should be yours!
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- DLM
- Our Trim Guru
If the scrappy one's no good I have a couple of s/h ones for a hatchback. A very small amount of of white rust crumble on the exposed parts, and Just a little bit of wear at the sphere end of the inner cylinder piston. I may post some pics of these anyway as I'd like a second opinion on the wear, though it seems minimal.
Cylinder/bore wear is about the least to think about Dave -
It's corrosion (i.e. NO such) that really matters
I use Xantia cylinders for repair as these are much cheaper.
They are 35mm bore like the the BX Hatch.
'96 on the Xantia Estate got 40mm bore cylinders (BX estate are 37mm bore).
BTW : any pinhole may be drilled out, tapped and blanked off with a small bolt using fluid sealant
- if suddenly realise you can not get that spare part now & here
- Ian_Fearn
I finally got round to getting a new suspension cylinder today. I plumped for a brand new one as i reckon my BX is worth it!
I couldnt believe my eyes when i saw what has happened to the old one.
Theres some corrosion and heavy pitting on the casting but it looks like a shotgun hole in the side of it!
Just a warning to everybody else out there!
