I have a broken pipe halfway along the front sub frame, it is the 3rd one down and I can't find where it goes to, any ideas or maybe even a hydraulic system diagram
Many Thanks
Adam
Hydraulics!!!!!
Hydraulics!!!!!
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1991 TZD Turbo (Breaking)
"Graculus" 1990 TGD Turbo (Restoring)
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
Dont think its broken. Look at the end of the pipe. Prettý sure you find that smallish bulbed special Citroen flaring some 10mm in at end.
This pipe is the return pipe from the rear HC. It connects to a rubber hose which is part of the bundle you can see in the engine bay RH (car's) corner. Must be a dangling rubber loose rubber hose down there somewhere near the pipe.
If you have truble finding it - then look at the NEXT largest rubber hose on the reservoir. Excatly this hose has 2 smaller hoses moulded on. One of these small hoses leads to the pipe down there.
BTW : the other one of these 2 small hoses is connected to the return from the front HC.
If you raise the suspension - then deliberately set it to low - you will see LHM frothing out the pipe above ...
Ok, thanks, i'll have a good look this weekend, got an endless list of jobs I want to do for peace of mind so might be posting again soon.
Thanks again
Adam
Thanks again
Adam
Previously Owned
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
1988 19DTR
1991 17TZD
1987 19GTI (Dads)
1992 17DTR (Mums)
Currently
1991 19TGD
