LHM Query
ellevie
Forum Treasurer
Post by ellevie »
Way2go wrote:Yes, started to use this when I was leaking from the Octopus & continued using it It seems no different to other LHM. :D
Good !, It's always worrying for fear you might put the wrong kind of oil in there. At £3 a litre it's hard to see how you could get it much cheaper, unless you get of the 20 litre drums from GSF which would bring it down to about £2.50 a litre.
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
thanuttiscotsman
Post by thanuttiscotsman »
hi there,
if it says it is ok for use in citroen lhm+ cars then it sould be fine, almost anything will work in these systems. i have taken a bx to the scrappers before that had no fluid in so i filled it up with rain water and after 25mins it rose up ¨airlocked¨ and went great in the field! :twisted:
though i dont recommend ever putting it into a car you will need again! :lol:
rossco
1996 transit 2.5di 80 swb
Stewart (oily!)
Post by Stewart (oily!) »
A mad bloke I know used cooking oil in the hydraulic system of a BX for months, I was expecting something to fail on him but it never did. Fine for getting a leaker home too, its more biodegradable than LHM.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
ellevie
Forum Treasurer
Post by ellevie »
One of the Citroen specialists around here told me that there was an old boy who came in from time to time who had used spent engine oil for years apparently without any disastrous effects. :?
BX19TXD 150k K Reg
I guess if its mineral engine oil, then it may be ok?
You have a collection of problems if you use fluids other than LHM. Amongst others they are:
Automatic transmission fluids - have 'Friction Modifiers' in them which presumably are something to make it less slippery for clutches etc. What are they - whatever they are they don't sound like lubricants - but the stuff works well in power steering systems.
Brake fluid - originally Citroen used vegetable (Castor?) oil in the system - but in the mid 60's changed to mineral - with a change in seals. Seals may deteriorate - and the stuff takes in water rather easily. What its lubrication properties etc are I don't know.
Engine oil - may not agree with seals - and is probably the wrong viscosity.
You will always find someone who has done something strange and got away with it. What you don't know is how well the car actually worked and rode and generally functioned - after all if you've been running the thing on old engine oil you're hardly going to tell your mates over a pint that its ride is terrible, it leaks like a sieve and the power steering doesn't work. More likely is that you'll use LHM and tell everyone you do something else!
Contact:
Buttercup Bob in Australia has been using Vegetable oil in his DS for years with no adverse effects but i'm not sure I'd go down this route.
As for ATF, there are different types of ATF and non of them would do the hydraulics in a cit any favours!
Chris G
I cant really see much of a cost advantage in potentially causing a shed load of damage by not using correct LHM, but thats some people for ya...
