Are you sure the smoke is oil? What colour is it & what quantity?Kingswell wrote:Actually regarding what I previously posted. I think that there is another small oil leak. Its on the gasket that seals the black rocker cover. I checked the oil again and it doesn't look like it has changed much since I put the kleen flo in. Considering how much smoke its been putting out there is still quite a bit of oil.
Could the smoke be an exhaust problem. The back section of the exhaust is filled with a very oily soot.
The exhaust soot could indicate that you are running very rich, maybe you aren't running the car much beyond the auto choke operation as I imagine most maltese journeys are quite short. Have you checked what your fuel consumption is?
If you are worried about oil leaks then maybe it's a good move to have the engine and bay steam-cleaned and then you will really be able to see what is coming from where and take quick remedial action if necessary.
