Reversing light switch
mnde
Meteor Man
Post by mnde » Thu Dec 28, 2006 12:56 pm
Hello chaps,
My reversing lights don't work, and I immediately suspect the reversing light switch hasn't been reconnected (car has had new clutch installed recently).
Can anyone tell me where I can find it?... cos out here (near Cardiff, on holiday) I have no Haynes BOL, and I couldn't spot anything obvious with my torch....
Cheers!
Mark.
1982 Citroen GSA Spécial Estate
1997 Renault Mégane RT 1.4e
1991 Citroen BX16 TGS Meteor - gone to Scotland
Post by docchevron » Thu Dec 28, 2006 1:56 pm
It's on the front of the box near the end of the clutch release fork arm, it has a plug on it and the whole unit faces towards the front of the car, the loom from the plug then has two further connectors under the battery tray mate.
Chris G
Post by jeremy » Thu Dec 28, 2006 2:30 pm
Should you need Haynes on your travels you can download one (Last edition - english) from here (top BX document - most of the rest if not all are english as well)
http://citroeny.cz/servis/servis.htm
mnde
Meteor Man
Post by mnde » Fri Dec 29, 2006 7:29 pm
Hi,
Thanks for the pointers!
Unfortunately the Haynes files I downloaded don't comprise the whole manual. It's missing Chapter 6 which I believe is the Clutch/gearbox chapter.
Doc: I've spotted a disconnected wire poking out from under the battery tray... so I'll have to have get the battery out of the way when I get the chance so I can get at it properly.
Cheers!
Mark.
Post by ken newbold » Fri Dec 29, 2006 9:17 pm
16 TGS you should be able to se and get at it easily enough with removing the battery. :?
The switch itself is almost right under the clutch arm mechanism with a two pin plug in that area which should be clipped onto the top foward facing part of the gearbox.
