I need to order a new octopus for this renovation project. What will GSF or other motor factors call it?
And what else do I need to order to fit it?
Thanks
O
What do you call the octopus?
I think the official name is 'Oil back harness' which seems to make sense.
parts list under BX here - its in PDF form and english and you may think worth keeping on your hard drive.
http://citroeny.cz/servis/servis.htm
- DLM
- Our Trim Guru
GS & F list it thus:
N43406 RETURN PIPE BX WITH PAS OCTOPUS RETURN PIPE 28.30
This is what some call the "large octopus".There is another return pipe assembly towards the front of the engine that merits the name of "small octopus". Both were fairly readily available at Citroen dealers about 18 months ago when I did 2 large and one small in rapid succession for a friend. Sadly, the BX that'd had both octopi was scrapped not long afterwards... for other reasons. If ordering from a Citroen dealer they'll probably need RP number to identify type (there's more than one variant of the small one).
- DLM
- Our Trim Guru
They don't list it any more AFAIK, Oscar - but consult el Presidente and he should be able to provide more info. I'd say it's worth doing the small one only if you have problems there, but can see the logic of a getting your preventative maintenance in first.
If you follow the return piping outwards from the reservoir, you should see the small octopus assembly heading out in the direction of the pressure regulator and FD, and draw your own conclusions about the desirability of a change.Compared to the large one it's a doddle to change...
- DLM
- Our Trim Guru
No - but then who expects common sense and car-part prices to go hand in hand? There seem to be a fair number of easily-tooled bits in this world that require removal of limbs to obtain. I suspect a number of 100% mark-ups along the way is the main culprit.
