Hi All,
The Bosch pump on my 1769cc N/A diesel has decided to eject fuel from the main shaft front seal.
Removed the pump, but it is not obvious if the seal can be replaced without dimantling the pump.
Anyone replaced these seals, if so are they readily available as a separate item.
Bosch Diesel Injection Pump
- ken newbold
