Why does my 1.9 D rev higher at 60 than my 1.7 tzd?
Any ideas to the above and what does higher revving mean for the state of the car. I.e. at 70mph in 5th i'm doing 32k to 35k revs!
go further on veg oil
- x 88
Because it has shorter gearing. The N/A's have shorter gears to aid acceleration as they don't have quite as much grunt as the TD's. Although the gearing is probably the same, and the final drive is probably more likely to be different.
But it really shouldn't be doing 32,000 to 35,000rpm.....thats a sign something is wrong.
1990(H) 16Valve (Rouge Furio)
- docchevron
- Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin' - x 12
- docchevron
Failed!!!
Only 10 items though
1.Horn not working (fixed tonight)
2. Nearside front velocity joint gaiter split
3. Nearside front suspension joint excessive play in a track control arm inner buch
4. Nearside front tyre tread (knew this already)
5. Offside front tyre tread (Knew this already)
6. Parking brake lever has no reserve travel (fixed tonight)
7. Nearside rear brake reacording little or no effort ( think seized due to left standing)
8. Offside rear brake reacording little or no effort ( think seized due to left standing)
9. offside front parking brake recording little or no effort (fixed tonight)
10. Parking brake efficency below requirements
Anyone see anything that would be a cause of concern? i think i can sort the rear brakes myself thanks to Vanny!
- ken newbold
Item 11 gives cause for concern.
The nut behind the steering wheel
I take it you never checked over the car beforhand. This to me seems totally senseless.
The main item to worry about I'd think is item 3, the inner joint on the suspension track control arm. I take it he mean the inner joint on the steering rack. Can be done but not easy I think.
- ken newbold
Hey guys
Yeah thanks for that
The car was sent in on a whim as i had fixed many other things but due to time constraints i needed to get a basic brekdown oif what needed doing.
Now i will be up all night worrrying about bushes, both inner and outer
Oh well as Vanny says anything can be repaired or replaced on a bx. Its just the time and £ that worrys me! and thats even before i tackle the gear box issues!!
- ken newbold
