I’ve always had very comfortable seats in all my Bx’s
But the seats in my TZD tend to hurt my back
It seems that they have a bit of a twist in them , has anybody else had this problem with their seat
And if so how did you sort it ?
TZD seats uncomfortable
Citroen BX
Origami in plastic and steel
^^bx>
^^bx>
My TZD seats are more comfortable than my relatively new Peugeot 307 and in my opinion a bit better than the ones in my previous 16V - the bottoms of them were too hard. If yours seem twisted, might be wise to remove them and check the seat frame isn't broken or bent - also that one side of the back or bottom isn't out of alignment with the other on the adjuster. Not sure if that can happen but if a belt has slipped or come off it might be the reason it seems twisted
cheers,
Roscoe
1991 TZD
2004 Peugeot 307
Roscoe
1991 TZD
2004 Peugeot 307
the other TZD's seats were much more comfortable and i could do hundreds of miles without any discomfort
but these seem to have a hard seat and a badly shaped back
i'll have to strip them down and see if anything is broken
PS
I did once see a Dutch web site showing you how to modify the seats in a TZD by fitting adjustable lumbar supports
(showing how to strip the seats down and what bits to weld on)
I think that some of the GTI’s had those seats fitted
That would be a good idea for long distance drivers
is there still a link to it ?
PS
Citroen BX
^^bx>
^^bx>
