Difficult starting
- sleepy0905
Difficult starting
Right can anyone help a couple of times now it is getting cold my car has not started and i have ended up charging the battery now i have had the alternator tested with a Gunsons start check and it says its ok i have also checked the battery with it and it is also ok replaced feb 2004 now i am wondering if it is a dodgy starter motor now i do have a couple of spare ones but i am after sugestions or ideas i have also disconected and cleaned the alternator, battery and starter connections including the earth? Oh yes and i am running pure diesel at the moment
Diesel cold start problems?
If its turning over but not firing could be the glowplugs on the way out / 1 or more failed glowplug. They last about 60 or 70k then they is buggered.
Glowplug relay working as it should?
Air in the system? Does your bulb go hard when pumped fnarr fnarr?!
Or is it trouble starting when hot - almost always an air leak.
When running is all as it should be?
Start with the easy stuff before pulling the starter motor to bits.
- sleepy0905
everything works fine normally even when hot its just occasionally it is realy slugish at turning over and wont start thats what makes me think starter motor as everything else has been checked did the glow plugs not that long ago i know she is due an oil change dut thats all
If you are sure your battery is up to it then sluggish cranking must be the starter or a loose connection somewhere, do you have an additional earth from the engine to the body as this piece of cable can sometimes magically cure a plethora of niggles.
Stewart
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
- sleepy0905
- sleepy0905
- ken newbold
Similar problem some years ago on a high mileage BX tzd ,somedays would, somedays wouldn't, convinced it was the battery so changed it, still the same, changed starter motor, still the same, eventually found it.
The positive battery lead. Where the cable is crimped in to the lead terminal, found that this had gone mouldy inside. Only reason I found it was, after several attempts at starting, leant over battery in dispair and burnt my arm on the red hot terminal.
Oddly enough it was only about 12miles from you. Is there something in the air down there
- sleepy0905
- ken newbold
- sleepy0905
Well yet again today it would not start so put the tester on again after charging the battery and getting it running. at first start up the tester showed the alternator overcharging but then under load with everything i can switched on it showed it as being undercharging with the alternator fault light on so i changed the alternator once the old one was on the bench i removed the regulator and brushes to descover the brushes virtually worn out but more alarming the armature is virtually worn right through with a 4.5 mm step in it and not much copper left so i think i can say it is shot. Lets see if this cures the problem.
- sleepy0905
- sleepy0905
Well it hasnt cured the problem the battery is charging at the mo as i have just flattened it trying so i am now trying to get hold of a new + battery lead as citroen want £17 for one and one of the other options is possibly a worn starter motor causing to much resistance.
But otherwise i am stumped to any sugestions welcome.
- sleepy0905
Well just been to the scrappers i have an earth lead of a xantia and a + lead of a pug 309 as it has the same connector block for the loom it looks a lot cleaner than mine so we will have to wait and see if this fixes the problem if not the only thing left is the starter motor.
- Citroen Sorceror
2024. TxD 1.9D estate. 'Wheelybin' - x 12
