in the gear box... any ideas?
just drain and re fill?
milky oil
- docchevron
I'd have said no to the noise. The milky looking oil is a water/oil emulsion which will still have some lubricating qualities and indeed if it gets really hot may go back to oil.
The noise is probably the clutch release bearing - does it change if the clutch pedal is pressed?
My TD has made noises from the gearbox/clutch ever since I've had it (8+ years now). All goes quiet when the clutch pedal is pressed which suggests to me its the release bearing etc aned I'll wait till something else goes before attending to it.
Incidentally near the top of the box there is a plastic vent - Is it still there? Is water running in its area which is getting into the box?
