Anyone tried these?
Anyone tried these?
http://cgi.ebay.co.uk/CITROEN-BX-CX-XAN ... dZViewItem
I've only ever used a filter wrench, but i'm thinking of getting a proper tool
tried this
Is that the proper tool? Looks a bit flimsy to me not knowing what its made of though
Here's another less expensive one that uses a 17mm socket/spanner rather than a 1/2" drive.
http://cgi.ebay.co.uk/CITROEN-XANTIA-BX ... dZViewItem
BX19TRS 118K E Reg 1992-2008
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
BX19TXD 150k K Reg
- docchevron
- docchevron
d
at least he is sending a good message to those who don't know about citroens, how many owners have you spoke to who have just binned thier bx's becuase the spheres had gone!
IF YOUR CITROEN SUSPENSION HAS BECOME HARD IT ONLY NEEDS REPLACEMENT SPHERES.. A CONSTANT "TICKING" SOUND FROM THE FRONT OF YOUR CAR DENOTES LOW PRESSURE IN THE ACCUMULATOR SPHERE, WHICH MUST BE CHANGED WITHOUT DELAY!! SPHERES ARE AVAILABLE ON EBAY, EITHER NEW OR RECONDITIONED. DON'T GIVE YOUR CAR AWAY FOR A BARGAIN PRICE - GIVE IT A NEW LEASE OF LIFE
enough said
Current.
- DLM
- Our Trim Guru
A sphere tool works very well if made from materials which are sturdy enough - I have a Pleiades one bought secondhand and which hasn't failed me yet. The Pleiades one is a little expensive, but the handle is sturdy enough to temp me to use that end as a makeshift hammer!
- kermit the frog
I agree with you simon for the cost of as complete set of spheres including the accumilator the suspension will be comfortable and the car need not be thrown away.
It's cheaper than a set of new springs and dampers for most other cars and easier to fit.( no fidling around with spring compressors)
I agree with doc's sharp chisel and large hammer though you can't beat a good hammer
My personal favourite is the 2.5lb club a trusty companion not too heavy but shifts most thing's
I think all travelling tool kits should have one.
Regards Kermit
Regards Kermit
- DavidRutherford
- BX Digit man!
I have one of these tools (the type with the 1/2" square drive on it) and I'm impressed with how well it works.
I've had a serious length of breaker bar on it and it's been fine. Removed a particularly stuck accumulator last weekend with minimum hassle. Even not-that-stuck spheres come off much more easily.
Recommended.
Recommended.
- MULLEY
