I need to check the idle speed on lumpy I believe I've found the coil but it's square not cylinderical is this the coil or is it some kind of condensing/voltage stabilizer unit? If so how do I test the square coil for rpm with the tachometer
I've found out it is the coil but from a 16v is there such a thing as a carburettor 16v ? Lumpy also has that air breather above the rad of a 16v
Lumpy also has the airbox of a fuel injected model also on the drivers side of the carb believed to be a Solex there is a large black box either an autochoke or some kind of other ECU
