This afternoon I commenced the removal of my Bosch pump. I followed all the instructions from the Haynes til I came to the final part :
In the manual they undo the sprocket nut and simply withdraw the pump from its mountings. I undid the sprocket nut and the pump remains steadfast.
Then I see that the pump in the Haynes is a Roto-Diesel and there are no further directions for the Bosch.
What have I to do? All mountings according to the manual are away. Do I perhaps have to undo that bolt that runs through that plate by the injector unions ( and also hold the throttle and idle cables). This is not the lower mounting bolt.
I thought I would pose this question here before I go dismantling further.
Typical Haynes, had the same problem with my Honda - it simply doesn't show certain variations.
I've got to get it out and in by four tomorrow afternoon, so any advice greatly appreciated. Cheers!
P.S one more question. How the devil can one do up the spocket nut again and get a torque wrench on it when one can barely squeeze a ring spanner in there?
How to remove Bosch pump?
This may be completely unhelpful, but when I removed the pump for my AX the plate holding the throttle cable anchorages had to be removed to allow access to a third mounting bolt, hidden on the back/underside of the pump. How many mounting bolts have you removed?
PS Fark knows, ask a 90s French assembler...
- Sir Jim of the Databases
Hi Todd,
have a look part way down this threadhere.
It's for the X****a but it should be more or less the same for the BX.
The pain is the nut right under the pump Be careful of the back bracket nut, it's screwed onto a tapered bolt that is hard to hold and can go walkies. Even more fun when refitting the pump.
Jim
Thanks for the replies fellas. I've already taken out the bottom mounting nut that you described as difficult Jim- I managed to squeeze a socket on it .
So that's three out - any others? But I can't in any way 'tease the pump out' yet. What is the nut that sits dead centre in between where the injectors exit? This plate with the throttle cable mounting I've already half dismantled ( it needed one Torx and one Hex bit! Why??)
I've stopped for today but I need to go in there tomorrow with the right idea.
Re: getting the right torque when the sprocket nut goes on, will very tight do?
Hi Todd,
There should be a fourth nut on the rear mounting plate that bolts the pump to a lug on the cast alloy pump carrier. It'll be (imagine you're looking at the back of the pump head-on) at around 5 O'Clock. It is in fact a bolt with a taper that pulls tight into the mounting lug on the pump carrier.
The bolt right in the centre of the HP unions is the timing access hole.
Well done with the lower nut. That one in the Xant is a pig due to the proximity of the HP pump and alternator..
Jim
Normally undoe the nut to the end of the threaded shaft but don't remove so it protects the thread of the shaft then strike hard once with a hammer! Once loose take the nut off and withdraw the pump.sdelasal wrote:thread from the dead I know, but how do I get the pump sprocket off the taper shaft? everything is loose. Steve
