toddao wrote:Well, I looked her up on Wikepedia - you can tell that I don't live in the U of K or watch TV. She's a star!! And a fit one too. Maybe she'll help out with my possible pourous head?
Alas I've ruined her for other men mate!
Ok, MANY possibilities here, most of which have been aired here already.
Porus blocks were an issue from June 1989 to the end of 1991, but only the 1.9 N/A. It was always the side of no.1 cylinder facing the flywheel that failed, everytime. I'm losing count of the number of these I've seen.
If it's any consolation I did 3 HG's in a weekend on my old 19N/A using two heads and had exactley the same issues as yourself.
This was engine number 2 after the original block went porus
Anyhow, it turned out the rad was fucked. The rad was new, well, 6 months ish old..
I never checked it as I just didn't expect it to be screwed but it was.
It got hot all round the edges, but the centre of the core was stone cold...blocked solid. I lost count of the number times I kicked the car and swore at it that weekend...
Although i did get the time to remove the head down to 27 minutes..
Being an early diesel I'm not sure you'll have the bypass hose from the front of the head but as said above it's worth checking all the hoses.
Also as said above, the N/A's, and some TD's can be utter bastards to bleed properly.
The funnel works ok, but much better to pressurise the system, either with a proper tool, or a rad cap with a hole drilled in the centre and wham an air line through it, or if you're lacking in compressed air, rig up an air line that you can connect to a tyre ona rim with some pressure in it.
The only other thing not mentioned is the diesel heater that lives down the back of the engine. The bottom hose attaches to it.
They can and do go porus, mainly cos they're made from that well known muchos cheap material Crapite, similar to Cheeseium, but more crap.
Again on teh old 19n/A that once adorned my TD the bloody thing went porus and gave the same symptoms, didn't do anything for starting the thing either...
Anyhow, good luck mate, and keep yer chin up.
