A quick question for anyone with a hatch - is there any kind of trim to fasten down/cover the boot carpet where it meets the rear seat back? I've just put in the rear seat from a hatchback, and it does't have the flap of carpet to cover the join like the estate seats did.
I could knock something up from an aluminium strip or similar, and rivet it in place but was just wondering if anything existed normally...
Hatchback boot trim
- mat_fenwick
- x 19
- MULLEY
From memory i thought that the hatch boot carpet had a very small flap that could be kinda pressed into the recess.
Mind you, if the plastic side pods are secured with enough pressure, that keeps the boot carpet from moving about anyway.
- mat_fenwick
- x 19
- MULLEY
i dont remember suffering from that, isnt there enough carpet material to put into the slot where the seats go forward? If there isnt, i'd be tempted to use some duct tape.
- mat_fenwick
- x 19
- MULLEY
It would look a lot nicer with an aluminium strip instead.
- Aerodynamica
- docchevron
Beg to differ but on both the BX 19 TRs and Later TZS circa 1990/1991 got the three lugs the carpet hooks into on the floor plan plus a velcro attachment to the rear split seat! From memory the split rear seats were fitted like that but not the earlier bench seat (Yes I was refering to UK spec)
1990 BX19 TZS Auto 06/11/1989
