how to change the starter motor ? can you help ?
a happy new year everyone !
I had a fair share of similar starter problems in the past. Eventually I realised that all I have to do is following the special instructions for a BX 1.6
Depress accellerator fully when I first start it and in the rare case it dies in the first minutes I press the accellerator fully.
Yesterday this happened to me again, the engine died after about 30 seconds of driving. I tried to restart it for a while but suddenly there was no response from the starter motor anymore. I tried again today and there it still does not turn at all. There is a click sound and the battery is fine.
Is the starter motor gone again ? (it is a valeo less than 2 years old)
Can I fix this by myself on that local street ?
- DavidRutherford
- BX Digit man!
Re: starter motor gone again ?
Have someone else turn the key to the "start" position, and while they're holding it there, give the starter motor a reasonable clonk with a medium hammer. It will now probably start.cacaolat wrote:There is a click sound and the battery is fine.
The starter itself is most likely fine... it's the solenoid that causes the problems.
- DavidRutherford
- BX Digit man!
Either the solenoid isn't closing the starter circuit, or the motor has gone high resistance.
On the side of the starter there should be a copper link from the solenoid to the starter motor itself. Measure resistance between this and the battery -ve terminal.. Should be quite low, well under an ohm.
- jonathan_dyane
- jonathan_dyane
- DavidRutherford
- BX Digit man!
Fish?cacaolat wrote:It is 43.2
Sorry, I'm being an arse now! (and I have no idea what Jonathan was on about with 39 steps?!?!) I assume that's 43.2 ohms. If so, the starter is very ill. That reading should have been under 1. Have the motor off, and take it to a starter reconditioner. It may simply be a high-resistance connection somewhere, or it may be stuffed.
- mat_fenwick
- x 19
Ok I have never done it before but this time I think I will fit my own starter motor....before that I will follow instructions and get all the meter readings and if necessary change the battery negative leads etc. HT leads too ?
I am finally fed up with this starting problems. (this was my 3rd starter motor already)
How difficult is it to replace a starter motor on a local street ?
I will buy my own multimeter soon.
- mat_fenwick
- x 19
If you have a set of good jump leads you can prove whether it is the battery leads or not. To check the negative lead, connect a jump lead from the battery negative terminal to the gearbox casing, making sure that the casing is clean before clipping to it. If it then starts fine then the negative lead is the problem.
You can do the same with the postive lead - connect from the terminal on the starter motor that has the big cable attached to it, to the battery positive terminal. Connect at the starter end first, and make sure the jump lead clip cannot either spring off, or come into contact with any other metal parts other than the terminal. Otherwire you will have some nasty sparks!
If this fails I have a known good starter you can have.
- jonathan_dyane
The 39 Steps is an organization of spies...collecting information on behalfDavidRutherford wrote:I have no idea what Jonathan was on about with 39 steps?!?!
of the foreign office of...(BANG!)
For some reason the wording of the question reminded me of a quiz, or the 'memory man' scene at the end of The 39 Steps film...
I'll get me coat...
