Wanted - BX TG hubcap
TG style hubcap required. One of mine came off on the road. Will consider single hubcap or a set.
Would also consider the TZ hubcap, or the old style peppercot hubcaps.
- saintjamesy89
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 124
Re: Wanted - BX TG hubcap
Hi, I have a set of TG style trims, they will need repainting though and don't have the dust cap covers. I can upload a picture later if you like.
2006 Lexus RX 400h SE hybrid
saintjamesy89 wrote: ↑Thu Jan 18, 2018 9:23 am Hi, I have a set of TG style trims, they will need repainting though and don't have the dust cap covers. I can upload a picture later if you like.
Many thanks. That's fine, as I can repaint the hubcap, no problem about the lack of dust covers.
Really only need the one, as one hubcap came off yesterday, and I will cable tie the others. How much is one hubcap plus postage? Let me know your email address and I'll pay via PayPal.
Kind Regards,
Nick
Just to double check you are both on the same hymn sheet , No. 9? These don't normally come off because they are held on with the wheel nuts ?
Defender110 wrote: ↑Thu Jan 18, 2018 2:52 pm Just to double check you are both on the same hymn sheet , No. 9? These don't normally come off because they are held on with the wheel nuts ?
Many thanks for the heads up. Hubcap no 9 in the illustration is the correct one.
Is bizarre that it came off; I've cable tied the other 3, between the slot on the wheel, and the small fitting holes where the valve cover normally goes.
- saintjamesy89
TBH I have absolutely no need for any of the four of these trims, my 14TGE is long gone. Yes, they are the same as no.9 'TGE/S/D' trims. Would you take all four as potential spares? You'd be doing me a service in helping me declutter the garage - the evenatual residence for my GT.
PM sent.
PM sent.
So if not - i would have some interest in the 3 spares. If you could find out what shipping to germany is about - would like to make a deal.
Thank you
Thank you
Pm Sent
Hi,
If there are any that need a home please let me know as a spare would be helpfully, The ones I have you can pull off over the wheel nuts, a friend did have a problem with hubcap blowing off and woeked it in the end at one of his wheels was not soild so the wind got thought he changed that wheel did not lose any more.
Kevin.
Kevin.
PM Sent
PM Sent
PM Sent confirming I've paid you via PayPal for 1x TG hubcap and standard 1st class P&P.
- saintjamesy89
Received, cheers Nick. Will try and post today.
Thanks very much Tom
Kind Regards,
Nick Yeomans
- saintjamesy89
Posted
