Wheeltrims wanted
Wheeltrims wanted
Im looking for a set of proper bx trims but not the TGE/TGD type.
Ive found a set of 3 on leboncoin but dont know what model they were off,poss a DTR.Theve got 4 longish slots around the edge and dont cover the wheel rim outer edge.
Anything considered,w.h.y.?
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- electrokid
I have some with the single straight line across the diameter with 'pennant' type flags at the rim if that explains it - £5 each + P&P - less for a quantity. Not bad condition (anything with chips out of the edge were dumped) still attached to their mounting rings so quite a lot of care required to remove the mounting rings so the mounting rings can be fitted to the wheel first.Anything considered,w.h.y.?
2002 C5 HDi SX estate
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
These are the sort of wheeltrims im looking for?
Richard.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
No but I want them, complete with the car! what a beauty! Is it a dieselRoverman wrote:The ones you want are the same as on this
- electrokid
