Yes, I know, this is the BX forum, but I'm not a member on the CX one, I know there are CX owners on here, so hoping someone will pass on the info.
This is all stuff that came from a former Citroen dealer about twenty years ago. I know very little about CXs so may well have mis-identified some parts. Any help with identification would be good. I'm away most of this week, so any questions will have to wait 'til I get back.
Offers welcome on the following:
6MA 5491 183 exhaust rear silencer most models.
MA SND 081984 identical to above
CI 641162 exhaust front silencer 51mm pipe diam. 4 bolt bracket at front end. Also marked 81303 and F001377. Should fit most diesel models, maybe others.
CI 641163 as above but with 2-bolt bracket at front.
95 596 564 hydraulic pipe, steel
???? Saloon rear wheel bearings x 2
???? Break rear wheel bearings (inc ABS) x 2
4MA 5440 812
95 496 237 Speedo drive connector/switch
4MA 9903 090 234 (also marked Z6 204 089) bearing (gearbox?)
??? several clutch realease bearings
1MA 75 523 052 rocker arm
???? handbrake cable?
1MA 7903 087117 large oil seal
1MA 7903 087076 ditto
1MA 7903 087109 ditto
ZC 9 612 555U ditto
??? several more assorted oil seals
96 024 261 aluminium heat shield
7MA 5 432 415 trim clips (x about 200)
7MA 7903 011 314 trim pins
75 491 596 fuel tank sender unit
??? water pump, double pulley, marked CX and C25 x 2
??? clutch marked CX 2.4i . No release bearing.
4MA 492 972 clutch or handbrake cable. CX?
??? rear wing/quarter panel for CX break.
CX bits for sale - new old stock
