I Need Counter Veglia for Citroen BX 16 TRS model 1984
I Need Counter Veglia for Citroen BX 16 TRS model 1984 .
- electrokid
The whole instrument cluster.electrokid wrote:When you say 'counter' do you mean speedo, rev counter, or the whole instrument cluster ?
Look this :http://www.google.com/imgres?imgurl=htt ... s=1&lr=all
- electrokid
If the instrument pod from this will fit...
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
then contact the seller.
2002 C5 HDi SX estate
pfg wrote:..................
Please try again with a good link !
Brian ! The /\ above link is for a MK2 BX, as it has mirror's, chrome/rubber side mouldings, smoked rear light cluster's and bumper which are all as used for a MK2 (Also the lower/rear wheel arches look bulged out which was a feature of the MK2 bodywork) !electrokid wrote:If the instrument pod from this will fit...
I doubt very much that someone has retro fitted all that to a MK1 (indeed if it was one), I think that the 'A18 GMD' reg. has thrown your thinking it was, that was obviously someones personal plate at sometime IMHO !
Also in another of 'pdg' posting/threads they've already made a request for the same item/s (With link's to photo's) :-
LINK to /\ thread, also as its for a LHD & probably in calibrated in Kph (As the main speed indication) version, there looking in the wrong country to source one as already pointed out by Phil Cpfg wrote:The color is gray. I am from Greece and i simply want to have also an other one.
Thanks
http://www.citroenet.org.uk/passenger-c ... -1dash.jpg
http://www.citroenet.org.uk/passenger-c ... auto-4.jpg
- DavidRutherford
- BX Digit man!
Copy and paste isn't hard...RxBX wrote:pfg wrote:..................
Very Funny David !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!DavidRutherford wrote: Copy and paste isn't hard...
I did exactly that (Copy and paste) but the search came back with the message 'Error NOT FOUND, The requested URL was not found on this server', hence the request for a new/good link, but after trying again (After reading your post) it does now work, so I don't know why it didn't the first time
- Tim Leech
- x 141
I so want a Mk1 with that dash! That car is a Mk2 though so wont be of any use sadly.
Registration Number : A18GMD
VIN VF7XBXB0060XB9736 Exterior Colour GREY
Registration Date 29/06/1992 Previous Registered Keeper 0
Engine Size 01580 Make CITROEN
Model BX16 TGS AUTO Model Year
Is Scrapped ? Yes Is Exported ? No
Is Imported ? No Scrapped Date 09/06/2010
Exported Date No. of gears 4
Fuel Type PETROL CAPCode CIBX16TGS5HP A
Transmission AUTO 4 GEARS Engine No. CT4H0003850
- electrokid
