Wanted: Hydraulic pump for 1.9 diesel
sleepy0905
Post by sleepy0905 »
Hi has anyone got a pump for a 1.9 diesel bx mine is getting tired and the steering is getting stiff plus she takes a while to raise up.
Mr B
Northern Moderator
Northern Moderator
Post by Mr B »
Have you tried an LHM change and a filter clean, it may help.
Stewart (oily!)
Post by Stewart (oily!) »
If you have trouble getting one Aaron I can send you one, they actually last forever though, would suggest belt tighten, LHM/Hydrorincage etc first.
Stewart
TZD 19 TD one of the few
Xantia Td estate, going soft
sleepy0905
done that stewart but my last pump seized up on the M1 and the only replacement i had i have no history on and you can hear it cavitating when it is running so i suspect it has a weak piston. How much would you want for one :?: :D
I don't see that a stuck piston would cause any noise at all - are you sure you haven't got an air leak on the inlet side? They leak inwards when they perish and often the ends get damaged on re-fitting. You may be able to see air in the reservoir.
sleepy0905
checked that there is no fizzing or bubbles in the lhm tank but if someone has a good pump pipe as well i will try that to see if the pipe is slightly porous.
tim leech
Post by tim leech »
U need some speedline alloys on that scooter of yours mate!
I believe the word is "You".
As for this pump... if it's cavitating, then there's definitely air getting in on the suction side somewhere.
Quick check: run the engine with the pressure bleed bolt undone a turn, and see if you get green guinness-type froth in the tank. I have a feeling there will be some.
Ander's suggetion is that to test the pump inlet hose you replace it with a section of clean garden hose.
sleepy0905
Ok thanks i will have a go i think i have some garden hose somewhere. Does anyone know where to get a replacement pump pipe from?
The scooter already has alloys what i need is some nice hydraulic suspension on it after all its body is made from the same material as most of the Citroen. :D :D
Stewart (oily!)
Hi sleepy, if you can find the damaged bit then plumbers 15mm copper pipe is a tight fit inside the original feed hose, I have a few spare pumps so you can have one for the postage.
Stewart
sleepy0905
Had a look absolutely no bubbles what so ever in the tank so i shall try the garden hose trick.
But i still think i need a new pump
sleepy0905
stewart if you let me know what the postage cost will be i will get a postal order sorted for you.
Stewart (oily!)
No problem sleepy, I will dig one out and box it up at the weekend, PM me with your postal address.
Stewart
