I've been prepping the BX for our French adventure next month and the spare wheel has been getting some close attention. Took it to the tyre man and it is slightly dished. Presumably a previous owner hit the kerb and swapped it with the original spare. Anyway, I am on the lookout for another steel wheel to match. The existing one will work as a spare for the time being but I am always a bit twitchy when I know something is not quite right.
Any ideas?
Xsara Forte 1.4i 2000
Kawasaki GPz550A4 1987
Well, your local breaker will have a wheel I'm sure as it's a common size. A lot of Fords and Pugs share the dimensions. PCD 4 x 108, 15-22 ET with a 65mm central hole. 14" of course.
Thanks for the wheel and the cuppa, Steve! Great to meet you, have a chat and see your lovely 14TGE as well. The wheel has now had the spare tyre fitted, balanced and cleaned. Much appreciated!!
