I'm hoping that someone out there may have the following going spare?
The sections that i need are:
Outer Section, small part at the bottom, not sure if anyone has got a piccy or a diagram that makes reference to this bit?
Inner Section required, not sure if its made up of multiple bits or not?
Or, is there a way to get these cover sections that i need fabricated?
This has been the frustrating bit in the whole project, actually finding one
Wanted - 16valve Cambelt Cover
- MULLEY
Re: Wanted - 16valve Cambelt Cover
Do you mean the plastic that shrouds the cambelt Matthew? Have you tried any of the Pug forums?
- MULLEY
I've got no idea, i've never seen a 16v cambelt cover, it appears to have an inner & outer section of which there is more than one part?? Which pug forums matey?
There's this one Mulley...http://psooc.com/forum.php" onclick="window.open(this.href);return false;
- MULLEY
Cheers, i laughed with the random question, "What model was the 1st Pug Gti" The answer was infact 205, i'd mistakenly thought it was the 505, doesn't exactly make the place all that credible??
