I need a replacement radiator for my 1994 Xantia 1.8i 8v (non aircon) as its sprung a leak, as its nearly £100 for a new one from GSF (same value as the car) does anyone know where I can get a cheap one new of used?
Ok so ITS NOT the radiator its the matrix thats leaking! if it cant be fixed in situ its a dash out job which is hundreds, plus the catalyst is buggereed, the SD1s MOT has run out and needs work, the 16v is poorly and the GTi bounces all over the place. Grrrr
