Rear number plate lights
Neil
Post by Neil »
Dear BX fans,
One of my number plate lamps has popped out as a lug has broken off. If anyone has one available, please let me know the price, including postage.
Please e-mail me on nwatson@kennedys.co.uk
Thank you
Best wishes from Neil
Keeper of the site Goat
Post by cavmad »
Might have on here, Neil. Will check and e-mail you if so. I take it it`s for a hatchback?
Vauxhall apologist.
Neil
BX No plate lamp
Post by Neil »
Sorry for the delayed response! Thank you for the e-mail. Yes, it's for a Hatchback - a 1989 BX 16 RE.
Post by cavmad »
Had forgotten being honest mate but I`ll have a look later on and let you know by e-mail!
Vauxhall apologist.
Brian
Post by Brian »
Hi,
I have repaired 3 of mine in the past, and they are still functioning.
Providing you still have the broken plastic retainer, all I did was this:
Stick some suitable thickness spingy foam under the retainer, then stick the other side of the foam to the body of the light.
As a precaution, use a cable tie from the rear of the light to the cable, this will hold it place even if the clip fails.
Good luck
Pic shows both retainer clips repaired
And a LED as well. Do you use a resistor in series? - if so what value?
Post by cavmad »
Anyone know if estate ones are the same?
Vauxhall apologist.
Brian
Post by Brian »
Yes, for the single leds, I used a 560 Ohm resistor..
For the interior lights, I use 4 leds in series, and no limiting resistor, have not blown any yet !!!...
x 54
I just cable tied mine around the wiper motor housing. Worked fine.
1983 16TRS (Sunrise red) - 1987 DTR Turbo est (Venetian red) - 1989 16 Valve (Venetian red) - 1990 16 Valve (Venetian red)
Neil
BX lamp
Post by Neil »
Unortunately I have lost the lug, Brian.
I just wondered if Cavmad had any success in finding a replacement?
Thanks to you all.
Bets wishes from Neil
Brian
Post by Brian »
Hi Neil,
Ok, if you tie it back to a solid part of the hatch lid with either cable ties, strong elastic bands, wire or similar, then it does not require the lug to hold it in place..
Good luck
Post by cavmad »
E-mail sent, Neil. Think I have finally located them!
Vauxhall apologist.
