Hi, i am looking for a set of lucas diesel fuel injectors ideally for a 1.9 turbo diesel engine, though a set for a bx tzd may be okay.The reason i need a set is my smokey xsara is running a lucas pump with bosch injectors and this seems to be causing a lot of fuel smoke under acceleration. So if anyone has a set please let me know how much you would like including postage,
cheers steve
WANTED Set of LUCAS td injectors NOT bosch
