Much loved BX RD Turbo - good home wanted
My name is Jon, and I have a 1989 G reg, white 1.7 turbo diesel which has been in my family from new. I now have a company vehicle and would have to repair this car, so have reluctantly decided to lat her go.
She has 80,000 miles on the clock, an MOT till 30th September 09 and the log book is present.
Returns 57-58MPG if driven very carefully, 53-54 MPG if driven moderately, 49 if driven hard.
Has never been thrashed. Has a tow bar and has towed a caravan for a total distance of I think 160-250 miles and definitely no more than that.
Hydraulics work fine - all of pipes replaced with nickel alloy 2 years ago in a slightly messy but sound job. Spider joint on hydraulics also replaced at the same time.
Spheres at rear need replacing now.
List of issues:
Rear suspension leaning to one side on drivers side - informed that a new suspension sub frame(?) is needed.
Gearbox hum in top gear - told that it's the selector guides have slighly worn, aligning unworn and worn parts of the gears and leading to the whine. No problems with gear selection.
Slight glancing front impact has cracked bumper on drivers side and deformed wing.
Composite bonnet has a gouge in the front centre.
Would be a good source of spares or could be done up into a good state and I would like it to go to an enthusiat rather than to the scrap yard up the road.
Call 01235-2***** if interested. Postcode is OX12 - Wantage in Oxfordshire.
Regards
Jon
** EDIT - Phone number removed - please use PM or email function.
List of issues:
Regards
Jon
JC-D
Re: Much loved BX RD Turbo - good home wanted
sounds unlikely to me ...jchurchmandavies wrote:Returns 49 if driven hard.
- DavidRutherford
- BX Digit man!
Really?Tourist wrote:sounds unlikely to me ...jchurchmandavies wrote:Returns 49 if driven hard.
Given that the seller has had the car from new, and hence has been driving the car for longer than you've been alive, I suspect he may well know what fuel consumption he gets from it.
Whereas you've been driving a BX for what? A couple of months at most?
Given that I can spank the nads off a BX TD estate and still get 48MPG, I suspect his figures are right on the money.
Seconded!! Any owner worth his salt will know pretty accurately what his own car will achieve regularly....and certainly will know better than someone "new" to a particular make/model!
My Turbo TXD is remarkably economical, even when driven hard. It is one of the main reasons I keep her and drive her regularly, as my "daily"!
Her average mpg, over the entire 12 month period April 6th 2008 to April 5th 2009 (financial year ) was a pretty amazing 54.3 mpg!
This is mainly urban driving, with the ocassional long trip and motorway thrash thrown in!
Specific "hard thrash" figures return a perfectly respectable 47.6 mpg, based on my stats recorded on a "per journey" basis, for trips when I've given her the beanz!
I have recorded journey figures as high as 62.4 mpg, if I've taken the trouble to drive as economically as possible.
I am pretty anal when it comes to fuel consumption figures on my cars, as I also use them to give me a warning of something becoming amiss with the performance, and hence needing to be looked at!
I've managed 36mpg with my tzd
- DavidRutherford
- BX Digit man!
I suspect your injection timing may be out, or the injectors are tired. It shouldn't really be possible to get into the 30's MPG from a 17TD engine, unless you're towing or in the worlds worst traffic (Central London etc.)Tourist wrote:that's impressive fuel economy, I'm pretty sure I get about 30-35 with mine if I'm driving it "hard" ...
- docchevron
I cant even get mine under 42MPG no matter how hard I drive it (and it does get, er, "driven"), and thats at it's current state of tune, which is 115BHP at the wheels.
- Philip Chidlow
- x 25
Back OT - regarding the car in question:
Sounds like a fair amount of work / expense to fix. Is this a viable for someone here?
