BX N/A diesel
- Ian_Fearn
BX N/A diesel
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 41511&rd=1
Just seen this lovely TXD on ebay. What do people think to the N/A diesels?
Its only up the road from me too
Over and out from me
- Vanny
BX 16v Ph2 - XPO - x 83
erm, to be honest, pretty much the same as a TD! If anything you can get better economy from the 1.9TD by simply not raggin it everywhere and sitting at 55mph i managed a whopping 71.6 mpg out of the 1.9td while it was in the 19rd shell, best i could coax out of the 1.9 n/a was around the early 60's both times the journey was around the 300 mile mark
- Citroen Sorceror
- x 88
Yep I'll admit it doesn't give the 16v nightmares performance wise. Its got literally just about enough poke IMO.
Religously does 45mpg whether it be towing or carrying a couple of engines, never gets hot or lets me down.
Wouldn't say its as refined as a TD, bit noiser and harsher sounding IMO. But by no means unbearable. Its almost boring to own as it just keeps going with no fuss. I had to sell a Honda once for the same reason.
- Citroen Sorceror
- x 88
Perhaps the TD in question was a rough'untom wrote:That has to be a rough 'un Richard. I've never known one dip below 50 MPG and I have always found the 1905 to be the sweeter of the two engines - or were you using it as a starter motor for the 16V
I actually meant to put 45+mpg but you beat me to it before I could edit!
I've only really ever properly worked out the economy once. Managed to squeeze about £41 in after driving on the light for a day or two. Obviously the N/A has a smaller tank than the TD, otherwise I'd have got a bigger bill.
I drove around for a just over a week to work and back. Then to AndyC's in Redditch. Picked a gearbox, an engine, a cyl head and various spares up from his garden and returned home with them. Drove around for another day or two before it wanted more fuel. The clock read 484miles since the last fill up. I took it back to exactly the same pump and managed to fit £40 in it again. I worked this out to be about 47mpg, but I'm not one with numbers. And this takes into account how I drive the thing, which is as if I stole it! Journey times in the estate are quicker than the 16v
Don't think its a rough one myself. I've had rough cars before (xantia!). This sounds noisy when cold, and quite noisy when warm But its always smooth, and only seemed slightly less refined compared with a friends TZD Turbo hatch. Mind you that had done 80k miles rather than 190k!
Rich
