Picked up a tidy low miles 16TRS today, its taxed and MOTed but hasnt moved for 5 months, on the way home I noticed the clutch getting sticky, the pedal itself seemed alot nearer the floor that usual and as result the clutch would slip if I accelerate hard in the lower gears.
Do you think a new cable would be a good idea first, as they are cheap and quite easy to fit, the clutch itself doesnt seem to drag and is quite light.
Thanks
Slipping Clutch
- x 151
Slipping Clutch
Can't you adjust the clutch the same way as a n/a diesel? or is the petrol adjustment in a different place? Don't ask me how to do this as i've never done it. I think there are a couple of levers & a spring with a screw on disc, somehow you've got to shift something on it to make an adjustment. TBH it would be handy if someone could describe how you go about this as mine could do with adjusting.
- ken newbold
An inner cable lube at each end would be the first recommendation as it’s been standing for some time. Also, check and lube the linkage and lever arm on the gearbox to ensure the arm is returning fully.
Centre plate could be dragging on the gearbox input shaft, usually this is noticed by a heavy and jerking foot pedal.
Regards
Regards
Since it had been parked up for 5 months my thoughts would be the clutch plate/flywheel may just be a bit rusty and the mech a little seized from a winter in storage.
Clutch pedal adjustment is certainly on the cards by the description and probably another one once the clutch has freed itself up with some running.
How to describe how to adjust the clutch via the internet? Well I have done it but describing it would be easier to get the haynes manual out.
Could be rust in the lower plastic bush of clutch release shaft in the gearbox. I once found this on a BX at only 30k miles from new having removed the gearbox to replace the perfectly good clutch, which had slipped sometimes and was OK at other times.
You may be able to see enough of the shaft through the various openings in the bell housing to apply plusgas. If it frees it, do it again with some oil.
Fred
Fred
