TU3 engine
I was thinking about the KN filter route, but mine's already louder than I'd like it to be! I'm sure I've seen filter body kits that have ducting to draw in cold air.... Last resort, like you say.
I think I'll service the Carb if I can get a kit for it. I don't know the exact model of Weber yet, but I'm assuming a 32/34 - whatever that means It's off of an A1-running AX GT that was converted to bike Carbs, according to the seller.
- x 88
Webber?? It should be a Solex 32/34! It\'s the size of the chokes.
The K&N\'s only make alot of noise under heavy load. With normal driving you wouldn\'t notice the difference unless you started thrapping it everywhere. Cold air feeds don\'t really work on these filters either; you\'re relying on air being blown up a corragated pipe at a filter in a hot area of the engine bay! The only way you really get a cold air feed to work effectively is with a sealed induction kit, which draws air directly from the mouth of the pipe. But those are on the MPFI cars obviously. Doesn\'t hurt to point a cold air feed at the filter though
One barrel is 32mm, and then when you open the throttle you get the 34mm barrel coming into operation as well. So you get the benefit of a smaller carb for low end performance, but a larger carb (effectively) for top end performance. On the 205 XS we had (same engine as the AX GT) you could notice a (small!) kick when the second barrel opened.
Ahhh - see, I know nothing!
This is the buggar:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 3D1&_rdc=1
This is the buggar:
- electrokid
- Stinkwheel
I wound in the idle mixture adjust screw on my standard 14TU with solex yesterday, its made a bit of a difference to the better on the initial miss/lurch it always did, which is nice.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
- x 88
If he starts taking the piss name and shame him on there. They usually rip people a new arsehole for it. How long you wait is down to you though!
Yeah - I guess that's what I'll have to do. What annoys me is I turned down a Carb and manifold deal from someone else because I didn't want to renege on my verbal agreement to buy this manifold. I got the Carb within a few days from that seller.
Trust, huh! I asked the seller for an address so I could pick up the manifold (or maybe try the Pony Express route) and I've heard nothing, yet. I'm not that bothered about £15, but it's the principle of the matter. I now realise that not all forums have the respectability and trust of the BXClub!
I think I'll just put this down to experience and look for another elsewhere. mumble, grumble
Edit: resolved eventually - got me money back.
- saintjamesy89
198x Citroen BX16 TRS auto
1991 Saab 900 16v convertible
2007 Lexus RX 400h SE - x 128
Not sure what Weber that is, it's certainly not a DMTL. Does it have any ID markings anywhere?scarecrow wrote:Ahhh - see, I know nothing!
This is the buggar:
2006 Lexus RX 400h SE hybrid
