Wanted
Wanted
N/S front foglight surround for the valver. The one that is on at the moment is a metal replacement that looks out of place. Cheers.
- x 88
Is this a ph1 or ph2?
Yes sorry guys, PH1 and it's the black plastic surround i'm after. At some time in the car's past it has had a metal replacement fitted which is now badly corroded i know i could de-rust and re-spray but would prefer the original type. Cheers Mark.
- x 88
Well if you get stuck whack it in the post and I\'ll gritblast it for you. It should paint up like new then!
Cheers Tim. Took the spare wheel and the cage out this weekend attacked it with a wire wheel attached to my dads Black and Decker and re-sprayed it all. Won't win any concours prizes but looks a lot better than before.
