BX memorial
- x 150
BX memorial
- electrokid
- docchevron
- docchevron
in a similar vein , I have these just around the corner from where I live
Flatmate I im sure it used to be a vauxhall chevette )
and more junk less food (metro on top of a renault 5 )
oh and if you hadent guessed, it represents a cheese burger
Probably not a 1000 then. It was still just a Minor when the screens were split.scarecrow wrote:I went down to collect my Uncle's old split-screen Morris Thousand
Do you remember the Million model? I wonder who was the colour blind tosser who chose that yucky lilac colour for this celebratory edition?
- electrokid
Headlamps were moved from the radiator grille (lowlight) to the wings in '52 and the split screen was replaced with the single curved glass screen in '57. 1947 - 1950 models had the 918cc side valve engine designed in the 1930s - not sure when the OHV was introduced.
Originally designed by Issigonis as a direct competitor to the beetle, his design called for a flat 4 engine but this would be a new design and he was overridden and the engine from the original sit-up-and-beg Morris Minor was used because it was immediately available.
That's why there's lots of space in the engine bay - enough to get your legs either side of the engine while sitting on the radiator - perfect position for re-grinding the valves - good in Winter too because you're under the bonnet and you only get a little bit of snow on your back
