Big clearout (Pic heavy!)
This is the first batch of stuff I'm clearing out... Just making a bit of space, but there is plenty more to come. This is just the Shed. There is the garage to rummage through next
Follwing items now sold:
Dash
Tailblazer
Full 16v Exhaust
GTi/16v Gearknob
Bumper trim thingies
Radio flap
Fog Lights
Glovebox
16v rubbing strips
Phase 2 16v tailgate in white. Part prepped for spraying, but needs work.
ABS ECU
Grey door pulls
Centre console (black)
Centre Console (Grey)
Headrests - All front, some cut down, a pair of TZD charcoals too.
16v Spoiler in black with lacquer peel
Black door pulls
Gear gator (Mouldy)
Dizzy cap, looks PSA-ish?
Black carpets
Rear lights
Postert bumper
Front wings, one has a bit of rust, the other seems good. White 16v.
Xantia 14" trims
Rear P2 shelf, complete and un-butchered with both clips and sunblinds
16v wheel, split and cracked:
Standard wheel in black, might clean up alright...
TU inlet manifold gasket (I think)
16v Doorcards
Tailgate seal
Wheelbrace + Jack (Possibly from a CX)
Hydraulic pipe
Trim clips
Light switch
Fog light switch
Window switches
Petrol Flap
Gear Gator
Mirror brushy things
Lock Pins
Rheostat
Arch spat (A bit battered)
Grey clock insert (would be good for mounting something into the clock tray)
Grey clock tray (uncracked)
Ignition barrel surround
16v seat base (rest of seat somewhere else)
AX GT seat fabric, can be used to repair 16v seat...
White grille, white paint a bit ratty
Black interior trim (lots of)
Dash
Tailblazer
Full 16v Exhaust
GTi/16v Gearknob
Radio flap
Fog Lights
Glovebox
16v rubbing strips
ABS ECU
Grey door pulls
Black door pulls
Gear gator (Mouldy)
Black carpets
Rear lights
Postert bumper
Xantia 14" trims
16v Doorcards
Tailgate seal
Hydraulic pipe
Trim clips
Light switch
Fog light switch
Window switches
Petrol Flap
Gear Gator
Lock Pins
Rheostat
- Philip Chidlow
- x 25
- maxgreenwood
Are you posting?
If you are can i bagsy the following:
ignition surround
uncracked clock tray.
other things i need if you come across them are:
black door rubber strip seal front driver's side
1x small flat head screw for steering shroud (hidden under steering wheel)
thanks,
Max
ignition surround
thanks,
Max
'90 16TZS (m), White, 86k
- My Cars: 1983 Citroën BX 14 RE
Re: Big clearout (Pic heavy!)
Do you have any of the Postert kit left?
- My Cars: citroen bx 19rd (now sold)
citroen bx 17tgd turbo repairs ongoing. (gone to the scrapyard in the sky)
citroen cx familiale awaiting possible restoration. (rotted away)
citroen bx 14 re. this ones a beauty.
classic mini race spec. - x 2
Will the postert bumper fit mk1 or mk2 and do you still have the boot spoiler please.
Thanks.
Andy.
Thanks.
Andy.
- x 151
Gents, this advert is 8 years old. I imagine the items are either sold or gone.
