FRONT STRUTS
- x 151
FRONT STRUTS
The front struts on the TZI are shagged, they stick and groan and generally spoil the car as it rides very poorly indeed, which is a shame as the rear had new arm bearings and spheres last year and is smoooooth as silk!
Before I end up mortaging mysel to pleides I though I would ask if anyone has a set of a great used ones?
I have done the lubrication tricks on the struts and also with the return pipes in a jar of LHM and its made it a BIT better but they still need changing.
Thanks
Thanks
- Philip Chidlow
- x 25
- Philip Chidlow
- x 25
R Edwards & Sons (Cit breakers/repairs)
Oak Lodge
Buckwyns Chase
Billericay
CM12 0TN
tel 01277 651486
info@edwardsandson.co.uk
Also you can make an online enquiry.
http://www.edwardsandson.co.uk/online-enquiry.html
Oak Lodge
Buckwyns Chase
Billericay
CM12 0TN
tel 01277 651486
It sounds worth going for Tim as long as you can be sure that you get the new ones fitted to Phil's old BX. After all, I paid about £80 from pleides for one recon strut a few years back and I think they have gone up to well over £100 now.Roverman wrote:Had a reply back, £100 plus carriage, will have to wait a bit longer I think!
- Philip Chidlow
- x 25
- Stinkwheel
Edwards will happily supply you with good used struts if you ask them, i bought one from them in about march, 40 quid i think it was.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
