Fuel gauge and handbrake
Two seemingly unlinked issues, but they both involve a dashboard, so I've bunged them into one thread.
The fuel gauge doesn't work on the Mk1. Well, occasionally, it sort of bounces up to where it should be. Briefly. My guess is that the sender is borked. So, how do I go about solving that issue? Do I have to drop the tank?
Secondly, the handbrake warning light only seems to illuminate when the handbrake is off rather than on. Well, it once lit up when the handbrake was on but generally, it'll flicker on and off while I'm driving. Presume there's a switch on the lever that I can have a fiddle with? Or disconnect... The handbrake does seem to release cleanly.
Re: Fuel gauge and handbrake
Just lift the rear seat. The sender unit is below the round plastic cover in the foreground of the picture:Dollywobbler wrote:The fuel gauge doesn't work on the Mk1. Well, occasionally, it sort of bounces up to where it should be. Briefly. My guess is that the sender is borked. So, how do I go about solving that issue? Do I have to drop the tank?
BX Van 1.9D -90 Gone.
BX Van 16S -90 For sale.
Depends on the failure mode. I keep one two spare ones that I can quickly fix in position in case of troubles, and then take my time off the critical path to go through the removed one. Usually they can be fixed.
The problem with the fuel sender may well not be where the connector plugs it but in the actual fuel tank unit.
It is a simple job of unscrewing and remoing the metal cylinder that drops into the fuel tank.......However most likely you need to replace that unit if you can source one.
*********BEWARE OF PETROL VAPOURS AND EXECRCISE SAFETY IN A WELL VENTILATED AREA WITH FIRE PROTECTION ON HAND***********
That means no smoking, naked flames (including women) or sources of ignition (disconect battery).
Our car had been in for some welding on the sills and the tank needed removing . From then on the fuel gauge was working like a yo-yo. Finally got around to looking at the problem and found the electrical connector was barely fitted on the tank.
A few months later and the gauge did not work again . I knew what to do this time
I know, I know.
Any way if it happens again , I'll cable tie it on !!!!!
I know, I know.
Land Rover Discovery TD5
In my experience, that's usually not a big issue with an RD.kiwi wrote:*********BEWARE OF PETROL VAPOURS AND EXECRCISE SAFETY IN A WELL VENTILATED AREA WITH FIRE PROTECTION ON HAND***********
Wanna betphilhod wrote:What he said diesel is a bit hard to light.
And yes my reply was overly cautious as I failed to see the RD in the signature.
Which brings up the thought that the fault could be related to fungus growth in the fuel.
1990 BX19 TZS Auto 06/11/1989
- docchevron
nearly always is on a diesel, especially if it's been sat around with a low tank for a while...
Diesel's pretty hard to ignite, compared to petrol anyhow, or the local curry houses vindaloo!
Just been out to fix these two problems.
Fuel gauge sender - I reckon it was gunked up. Removed by unscrewing the plastic threaded ring and then I could pull the unit out. Bent out the two metal tabs that hold the plastic cover at the bottom off. Quite sludgy inside. Didn't look like fungal sludge thankfully, and the metal cylinder itself was clean bar a covering of diesel. De-gunked it all, squirted some contact cleaner on the connections just for good measure and it seems to be reading properly. Reminding me I need to get some fuel...
Job sorted and on to the handbrake. Took a while to work out that I needed to remove the little oddment tray on the rear of the centre console but with the two bolts removed and the electric windows disconnected, I could access the switch. Which is clearly broken. The plastic tabs that should hold it in place have snapped off. Someone had tried to bodge it with masking tape! FAIL! Now disconnected until I get a new switch. Hardly a priority. 2CV doesn't have a warning lamp for the handbrake and I seem to cope...
Thanks for your input!
