Wanted: Clutch pedal spring (are mk1 and mk 2 the same??)
- My Cars: CCC X**tia Columnist!! forgive me for I was led astray..
1984 Citroen BX 16TRS restored and now with fully functional power steering..!
1994 Citroen Xantia 1.9 TD SX (Jan 1994, no airbags but antisink fitted)
Hi guys sorry i've been away for so long. To be honest I'm not much of a forum/internet person really lol and i've been busy trying to find work and other things. But you all know the BX is in safe hands, right?!
Well the BX broke big time after it came back from the garage the second time and there may have been a few accusations of it trying to commit suicide and kill the driver. To cut a long story short the carb cuts out at idle or on the overrun...then the steering pulls hard left..so on a roundabout you get catapulted towards traffic waiting to enter...aren’t old cars fun?! Graham came up and looked at it reckons I need a new carb and for the moment pulled the accelerator cable out futher. As for me well I just swore at it and put it in the garage...now I’m thinking i should try to get it out.
For the moment I really need a new clutch pedal spring. Hope I’ve got the terminology right (?). Basically it’s the spring that attaches to the top of the clutch pedal and the bulkhead and extends when you put your foot on the clutch.
So i need to know:
1) Are the springs the same on mk 1s and 2s?
2) Where are they available from? Dealers only? I'm assuming its unique to Citroen too and i can't nick one off a Peugeot? I’m guessing I’d need a new one as if i get a second hand one won't it be just as bad as mine? (mine extends but doesn’t contract).
I suppose I should ask for a rough idea of cost too?
If I replace this you see it may actually get on the road despite the carb issues…we could really do with a working spare car right now (xantia has a few issues).
On the plus side..teh bonnet looks ace as do the sills i'd gladly show you some photos...but its stuck in the garage....
Thanks in advance and hope your BXs are behaving,
Phil
P.S bit of a long shot but has anyone seen any decent hdi xantias about?
So i need to know:
Phil
regards
Phil & Earl
1984 Citroen BX 16 TRS mk 1 "Earl" restored sept 2011 and now with fully functional power steering..!
1994 Citroen Xantia 1.9 TD SX (Jan 1994, no airbags but anti-sink fitted)
Phil & Earl
- x 151
Re: Wanted: Clutch pedal spring (are mk1 and mk 2 the same??
Your on the wrong forum to ask that, Xantias are the work of the devil!PhilGreaves wrote:P.S bit of a long shot but has anyone seen any decent hdi xantias about?
fair enough..had to ask..always liked sinkers with the XUD though..Roverman wrote: Your on the wrong forum to ask that, Xantias are the work of the devil!
anyway back on topic..clutch spring thingy? Any thoughts people...though i guess i'd really need to speak to a mk1 bx owner/expert..lol any left? Just take a quick peak at a mk 1 and then a mk 2…
please help please help. I promise i'll come onto the forum once a week to update you. Or never again if you prefer
the ridiculous thing is i used to have access to citroens own parts catalogue but i've lost the address.
thanks
Phil
regards
Phil & Earl
Phil & Earl
Managed to get a photo- hopefully its good enough so you can see waht an earth im gonig on about!
As you can hopefully see the spring attaches to both the bulkhead and the top of the clutch pedal . It’s about 10cm long (though I admit hard to measure in situ).
So could someone please tell me if it’s the same as mark 2s etc? lol…go on stick your heard underneath your mk 2 bx dashboard and have a peak! Without this spring being replaced I’m not sure how to go about getting it out of the garage- its got a lot worse so it’s very difficult to find the biting point, which combined with the carb issues makes it difficult to manoeuvre at slow speeds...such as backwards down a gently curving driveway...
If it is the same as mk 2s is it still available new? Obviously due to the nature of springs I’d like one new. Though I think I’ve found a few second hand sources…..
Thanks
Phil
P.S Hdi xantia search is over...
regards
Phil & Earl
Phil & Earl
- CGATCX25GTITURBO
Go on then, it's the same as my MK2 TZD by torch light on a freezing cold night in my pyjamas.PhilGreaves wrote:Just take a quick peak at a mk 1 and then a mk 2…
thanks
Phil
Thank you so so much. You don't know then trouble this has caused me!Defender110 wrote:Go on then, it's the same as my MK2 TZD by torch light on a freezing cold night in my pyjamas.PhilGreaves wrote:Just take a quick peak at a mk 1 and then a mk 2…
thanks
Phil
Now all i have to do is find a replacement...probably from someone stripping down a mk 2. Off to ebay then.
(obviously if anyone from heres got one let me know- incredibly high price paid)
As for what it does as far as i acn see it basically resests the clutch pedal to the normal position when you take your foot off. Or in my case very slooooooowly does this....
Anyone thanks very much for that
Phil
P.S lol you couldve left it till this morning. Though i suppose then you'd have done it in 'snow'..
regards
Phil & Earl
Phil & Earl
Phil
As Tim has said you need to check your cable or the pedal spindle to make sure all is moving freely. As CGATCX25GTITURBO has said;
All this spring does is pull the pedal down (cable up/outwards) to maintain slight pressure on the cable to take up the slack. It is not a clutch pedal return spring as fitted to vehicles with hydraulic clutches. The one in your picture looks fine and not in need of replacement?
Oh .....<censored> whats the rule on swearing on here?!
Apologies to CGATCX25GTITURBO and Defender110...your right im wrong. (nothings changed there then! ).
i don't know why but i remembered physics at school..something about a spring under presure will twang..Sure enough it does.
So; clutch cable. No hasn't been done. As far as i can tell from my limited service history its never had a clutch change either..please don't tell me it needs this- we've already got one citroen needing a clutch change. The smug look on my dads face would be more than i could bear!! (he's got an Audi which seemingly never fails..)
So clutch pedal is slow to rise, sort of hard or spongy feeling when pressed. So hopefully the cable (i spy a few on ebay); if so does anyone know how many hours labour this will be at a garage? I'm presuming the clutch cable is the same on mk 1s and 2s?
mind its only 8 steps in the haynes manual...is it possible for me to do this myself? If i can get the nuts off the bracket- knowing my luck i wont have the right size socket. Mind then i'd have to adjust the clutch. Go on someone tell me how simpe it is? To be blunt im running out of possbilities..
Oh should also mention- the spring underneath the bonnet on the clutch operating lever- how important is that? Mines pretty slack to be honest..
thanks
phil
(<censored> brake light is out too- how?! its done nothing but sit there!)
Fast approaching my basil fawlty impression to be honest.
thanks
phil
regards
Phil & Earl
Phil & Earl
Tim, have you ever changed one personally ?Roverman wrote:If its never had a clutch then most likely thats the culprit Phil, but I would start with a cable, they are easy to do and cost about £7!
Anyone with a basic mechanical knowledge (and a haynes manual) can do it.
As your aware I'm pretty good at most repair tasks on BX's and XM's and having changed quite a few clutches and clutch cables in my time on various vehicles, personally IMHO I've never looked forward to changing a clutch cable on a BX as there quite a Bar-steward to change (due to the lack of access between the engine and bulkhead) also hooking up the end of cable to the clutch lever is sometimes awkward too, compared to other makes of vehicles, (i.e. a 'Fix Or Repair Daily' ) but a BX one is easier than one on a 2.1TD (manual) XM !
I've seen/tested (In the the past) a few BX's which have had a recent clutch cable changed by an incompetent garage or a novice DIYer where they've allowed the inner cable to chaff the bulkhead entry usually due to poor fitting of the outer cable rubber grommet shroud/clamp plate or leaving it off or even omitting one of the self tapping (Bulkhead) retaining screws !
Hence this can cause a poor cable/feel to the operation of the clutch and thus in time the premature cable failure thro' chaffing of the inner cable (if incorrectly fitted) !
On the BX's I've changed clutch cables on (both N/A and Turbo Diesels), I've always had to get them up on car ramps (On the drive) to enable decent access from the under side of the vehicle to aid the removal/fitting at the bulkhead/pedal-box end of the cable !
If you personally have or the use of a four post ramp or better still a two post lift it will help to reduce the fitting time !
- x 151
Yes a while ago, fiddley but with this being a 1.6 petrol its a bit easier than an oil burner. Its worth a try for what they cost, as the car isnt being used at the moment take your time with it.RxBX wrote:Tim, have you ever changed one personally ?Roverman wrote:If its never had a clutch then most likely thats the culprit Phil, but I would start with a cable, they are easy to do and cost about £7!
Phil,
Have you greased the L lever clutch linkage (link the clutch cable to the release lever)?
This L lever bearing is a common failure for seizing. I would recommend that this is unbolted and lubed first.
I have done a couple of clutch cables on my MK1 and you need good underside access to feed the pedel end of the cable in. (usually two people, one to feed the cable in to the bulkhead and one to pivot the clutch pedal and capture the cable
Neil
A476 RBX
Series 1 BX 16TRS
A476 RBX
Series 1 BX 16TRS
