1989(G) Axonite Grey BX GTi Automatic
nomisf
Post by nomisf »
Hi All,
We have had this BX for about a year, has served well until it mysteriously stopped running a few months back. Its not in bad nick, Lacquer is peeled on the roof, but I can't see any rust. It will start and run until it warms up, then sounds like the timing goes out and it refuses to run until it cools. I don't have the time to fix it, and am looking to go for a jap classic this time anyway!
It has MOT until August 1st 2012 and no tax, will need to be trailered away.
If no one wants it, its going to the scrap yard in the sky at the end of the week, otherwise 200 ono takes it.
Any questions to spafrost@gmail.com.
Located in Reading, Berkshire
BX 19 GTi Auto
x 150
Sounds like a fuelling issue to me?
Please dont scrap it, they are getting rare now!
Try unplugging the vacuum advance (it actually retards it but hey) hose from the dizzy and blocking it off.
BX Meteor
Re: 1989(G) Axonite Grey BX GTi Automatic
Post by BX Meteor »
nomisf wrote:Hi All,
Where do you live (closest town if rural), if you're near me (Loughborough) I'll contact you
If you're not near me, it's still a good idea to post your location to get interest
DON'T scrap it! :( Anyone on here interested?
Location, location, location.
nomisf
Post by nomisf »
Ah, thought my location was being displayed.
I am in Purley On Thames, Just Outside Reading (RG8).
I have been trying to get it running for months, It has new or tested second hand everything, dizzy/rotor arm/cap/relays/fuel pump/rail/injectors. The only thing original is the ECU and metering head.
I dont want to scrap it, but its now at the point where I just don't have time or motivation for it, nor the money to spend tracking down difficult parts - hence my offering it here first!
BX 19 GTi Auto
nomisf wrote:Located in Reading, Berkshire
:lol:
adamskibx
Post by adamskibx »
My guess would be the air-flow meter has a fault meaning it's fueling too much, and as the engine gets warm it's just too much fuel. Does it run at a fast idle without stopping (eg 2500 RPM)...As a car of this age idles at around 850 RPM, the tracks in the airflow meter can get worn in one place as even though it is roughly still, the marginal fluctuations in idle speed can wear out the track at this point. Does it start to smell rich from the exhaust? Either that or there is a split somewhere in the air inlet piping meaning its metering a certain amount of air and only getting this certain amount minus the bit that escaped. Mind you, being a non-turbo it would be a vacume meaning too much air and not enough fuel.
As a crude test, mark the position of the air flow meter tuning allen bolt and experiment by turning it out to decrease the fueling, then if that fails turn it in to increase the fueling. In fact rather than marking the position it is just as well to count the number of turns to the fully screwed in position.
I would check these things and then replace the ECU. Should make a decent car for someone. I don't know my auto's that well but I would guess that there is some kind of added complication too.
Also, I don't know if the GTi has one, but some cars of this era have a wax-stat operated flap that takes warm air from the exhaust manifold when the cars cold, and cold air from elsewhere when its warm. Could it be that this has failed or that one of the passage-ways is blocked?
Adam
BX Meteor
Post by BX Meteor »
nomisf wrote:Ah, thought my location was being displayed.
Damn, too far for me ....anyone else interested in a BX with 5 months MOT for £200 ?????
adamskibx
Post by adamskibx »
It would be a great buy for someone. I would buy it but now is a bad time...In the unlikely event its still available in a month or so I would, but somebody is bound to get this one before then. It looks really smart.
Not another petrol not running right :?: :wink:
BX Meteor
Post by BX Meteor »
:lol: :lol:
Anyone know what happened about this car? A GTI auto would definitely be on my shopping list if I had any dosh - which I haven't (anymore)
