New Member-TZi Auto
New Member-TZi Auto
Hello to everybody! I have been advised to join this forum via Autoshite as you are a friendly and informative crowd on all things BX.
Brian is the name, a man of Kent, mid 60's, retired, divorced, so i can have as many cars as i like without any worries. Self employed for 40 years involving cars,vans or lorries,usually driving them.
Anyway,the Citroens in my life. I have had a Traction Avant, a couple of CX's, and a BX diesel. I needed an automatic car so thought i would try another BX.
I arranged with the seller of the TZi to view it on Saturday morning. Well the car was sort of described correctly, but i have viewed enough cars in my life to always expect the worst. It obviously needs a new exhaust and new nearside door mirror. The paintwork is as flat as hell though and will need a lot of hard work to restore it to some sort of shine,both corners of the front bumper need realigning and there is a scrape to the nearside of the rear bumper. It has good points though. 42000 miles, MOT, new radiator, 4 new spheres,it drives ok,changes gear well and at the moment everything electrical works. So a deal was done and i collect it Tuesday or Wednesday when i expect more will be revealed on the drive home.
Update to follow.
Update to follow.
Re: New Member-TZi Auto
P-ss off! only kidding , not another petrol one ! Very welcome aboard the mad house.Vantman wrote:Hello to everybody! I have been advised to join this forum via Autoshite as you are a friendly and informative crowd on all things BX.
Hi and welcome to BXC Brian, you've secured a nice spec. model with very mileage, so well done !Vantman wrote:............. It obviously needs a new exhaust and new nearside door mirror. ...................................
Update to follow.
With it being a TZi the N/S mirror will be an electric one, so I don't know if its just the actual lense your needing or the whole housing/assembly ?
But I did notice some on E-Bay advertised however these may only be electrically operated (which have the one Yellow plug) yours may also be heated so will have an additional White plug (best to wait/check what's actually fitted to yours to be sure) !
Ad. #1 PLAIN-ELECTRIC
and
Ad. #2 PLAIN-ELECTRIC
I hope it may be of help for you ? Enjoy your new BX (When you get it)
New Member TZi Auto.
Dear Brian.
Well done indeed Brian I think you have been very very
lucky indeed, they don,t come up like that with that kind of mileage on
very often
I just 4 months ago, with a lot of help from the very very kind
people on this forum to aquire a white ' 93 BX 1.6 TXi saloon auto
with sunroof, ABS, air-con, pram handle spoiler etc, with FCSH and
one lovely very very carefull owner with 47,000 miles from new
They all are a lovely bunch on here, so very thoughtful and all
very helpful too, it doesn,t matter how silly the question may be
either
I look forward indeed to more info Brian
All The Very Best.
Vince.
very often
either
All The Very Best.
Vince.
47,594 Miles from new.
Owned for 3 years sorned.
69,000 Miles from new.
Owned for 15 years T & T.
Electrokid is also Brian and still active.BX Meteor wrote: A slight caution for you, I'm also Brian, so be careful not to confuse digs made about Brian ... on the other hand ...
Welcome Brian (the new one ), look forward to seeing some piccies & the good & the bad bits, sounds like a nice car though
